OBDII Scanner
Steele
Full Name: Gareth Steele
Nickname: Steel
Home Town: Jhb
Has thanked: 92 times
Been thanked: 63 times
OBDII Scanner
Post by Steele »
Hey guys, I want to get an OBDII scanner for my Trol to be able to read the engine codes, Reading up, there seems to be some compatibility issues with some vehicles. I see there are a range of scanners available from 150 bucks upwards. So my question is, what do you use or recommend? I have a madman already so don't need to monitor those engine parameters, just the fault codes. And I drive the 3.0 CRD. Thanks!
Cheers, Gareth
Spike
Full Name: Spike Pretorius
Nickname: Spike
Home Town: Milnerton
Home Language: Sleg soutpiel
Has thanked: 77 times
Been thanked: 87 times
Re: OBDII Scanner
Post by Spike »
2008 4.8GRX. I've tried several units, connecting via a multitude of protocols, and can get none to read anything other than voltage
:oldtimer:
Sardonic Fattist
Re: OBDII Scanner
Also interested to see what options are available.
Re: OBDII Scanner
There is a lot avalable here at the China Market for arround a grand test it and buy the one that works . :mytwocents:
