Oil seal on the front diff.
ArthurKinnear
Full Name: Arthur Kinnear
Nickname: Arthur
Current 4x4: 1981 Nissan Safari
Post by ArthurKinnear »
Hi everyone, just signed up and introduced myself.. :biggrin:
I have a 1981 Nissan Safari.. Just got it and eager to get it rolling..
I've Googled around but cant seem to find a definitive answer.. Conflicting info..
Front left left wheel was leaking gear oil, i pulled it apart to see where its coming from and have found it a little confusing.
I don't see an oil seal between the drive shaft and diff housing "tube" to stop the oil entering the hub. I don't see how one would fit in there either, the gap looks too small. Looking at the diagram off the online manual it says there should be one.
But looking at the shaft and the housing, i don't see how an oil seal could fit there..
I'm pointing at the outside of the shaft (Left of the picture) , it doesn't seem right.
Any insight would be highly appreciated, else i'm forced to strip down the other side to get an idea on what's going on.
Never expected a simple oil leak to confuse me this much.. :think:
Thanx for reading..
Has thanked: 1126 times
Been thanked: 1043 times
Re: Oil seal on the front diff.
Confusing indeed.
I have not worked on a Safari yet, but the oils seal is definitely present on my Y60 and the Y61's as well.
On the other hand, it certainly doesn't look like there is a journal on that shaft for one to seal on...
Couple of guys who may be able to help:
1) Graham. zero83 4one7 75zero3
2) Chris Boegman (Bogeyman)
let me have your E-mail address - I can mail you the actual workshop manual [OR ask Kobus Pienaar aka "Herrie op Safari"] to post you the CD/DVD with the manual in PDF
juice
Full Name: greg justus
Nickname: juice
Home Town: benoni
Current 4x4: patrol 2001
safari 1984 wagon
safari 1982 wagon
Home Language: english
Has thanked: 1 time
Been thanked: 12 times
Post by juice »
I had the same issue when I rebuild my front diff ' the older ones did not have a outer oil seal,
There is a oil seal on the inside at the pumpkin which has to replaced '
The oil will run into the tube and over the years it filled up and started to leak ' if you
Park at a angle with the left wheel lower you will proberbly fine it leaks even more
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
those seals are inside next to the crown wheel and pinion and if you look at your side shaft too you will see where the smooth machining was done ,that is where its running ....K@K job
Kagiso II wrote: 25 Jun 2018 20:24 let me have your E-mail address - I can mail you the actual workshop manual [OR ask Kobus Pienaar aka "Herrie op Safari"] to post you the CD/DVD with the manual in PDF
There is a link to all reference manuals (including Safari) here: http://www.patrol4x4.co.za/viewtopic.php?f=42&t=7667
:salute:
ArthurKinnear
Nickname: Arthur
Thank you everyone...
All the help is much appreciated!!!!
:bravo:
Arthur, follow the links to a manual:
http://patrol4x4.co.za/viewtopic.php?f=73&t=7805\
:biggrin:
