I was chatting to my dad and he mentioned a story where an engine was destroyed due to a vaccuum operated difflock.
So one of the diffloc vaccuum lines had a break in it. So the whole time it was sucking air into the manifold. Not a major issue until the car started doing some wading. The engine proceeded to fill up with water until it died.
So be aware and check those lines!! If your diffloc is not working check or blank off the lines.
Patrol Diffloc and potential to ruin your week.
- Has thanked: 1067 times
- Been thanked: 985 times
Re: Patrol Diffloc and potential to ruin your week.
Did he witness this first-hand?
I find it hard to belive that enough water to make a difference can get through the small holes in the solenoid.
- biggles
- Full Name: Steven
- Nickname: Steve
- Home Town: Durbanville
- Has thanked: 20 times
- Been thanked: 87 times
It was not a patrol. It was one of his work mates cars... battling to remember the make now. Pretty sure it was a defender.
- Has thanked: 189 times
- Been thanked: 336 times
Dies the 4.8 and 4.5 draw vacuum from the inlet manifold or from a vacuum pump like the diesel's?
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
Petrol engine trek van manifold af en dan deur sy selanoids na difflocks toe en hy gaan baie lank moet suig om daai tanks vol te kty en dan manifolds toeMichael wrote:Dies the 4.8 and 4.5 draw vacuum from the inlet manifold or from a vacuum pump like the diesel's?
Would be nice if you could find out for us. Defenders don't have diff locks (apart from the centre diff) as standard.biggles wrote:It was not a patrol. It was one of his work mates cars... battling to remember the make now. Pretty sure it was a defender.
- Dustin
- Full Name: Dustin Roberts
- Nickname: Dustin
- Home Town: Port Elizabeth
- Has thanked: 42 times
- Been thanked: 52 times
Let's look at facts here.
Land Rover Defenders break for no apparent reason, even if the wind changes direction
I should know because I had one before I realized the error of my ways and bought a proper 4x4.
Peter is correct in saying that they don't come standard with rear diff locks.
I also find it highly unlikely that such a marginal amount of water sucked through the vacuum line would be enough to kill an engine, unless it was spending a prolonged time submerged under water.
I agree with Biggles that it's not a bad idea to keep checking the vacuum lines from time to time.
I generally check mine at every 2nd service.
I have a vacuum leak before and it was not a fun experience, especially because I was in the sticks and needed the diff lock to get me out of the trouble and back home.
a.k.a. Datsun Dustin
GO PATROL !!!
GO PATROL !!!
