ZD30 cheap rebuild met fotos
Has thanked: 293 times
Been thanked: 288 times
Re: ZD30 cheap rebuild met fotos
Post by ricster » 19 Jan 2016 11:47
I like my old school td42 even more now.....hahaha
Another line of thought..... cause I'm having second thoughts about the over fueling thing. Does the ZD30 have oil squirters under the pistons? How is the bore and rings lubricated on the ZD30 motor?
Just thinking that a lack of lubrication on the bore and rings causing excess heat and heat seize. That piston doesn't look burnt like mine did, yes the shape of the pistons is very different to the TD42's but look at the edges of the piston. Yes they look a little banged up, but not really melted. Look at the piston damage on my piston when I burnt a hole through it.....
viewtopic.php?f=44&t=1266&hilit=burnt+hole#p11167
That ZD piston looks more scratched with "square" edges. On my photos the TD piston has rounded edges where it burnt away or melted.
PaulvdMerwe
Full Name: Paul van der Merwe
Nickname: Paul
Home Town: Graaff Reinet
Current 4x4: 2001 Patrol 3.0 DI GRX
Been thanked: 6 times
Post by PaulvdMerwe » 19 Jan 2016 13:14
Thanks to all for your input,
It is highly appreciated.
1. The Injectors, the ZD 30 uses normal injectors, not the electronic ones. so I will have them tested as a precaution.
2. Lubrication, This was my first thought as well, but I removed the nozzle and it is clean and wide open.
3. I will strip the intake manifold of this afternoon to check the valve intake.
From my personal experience, piston crown failure (which looks to be the case here)is caused by overheating of the piston, this is in line with all your thoughts, so now we just have to establish the cause of the overheating on this piston.
Let your opinions roll in, I learn from all you guys.
Post by ricster » 19 Jan 2016 13:31
As do we learn from you bud !!
I'm still inclined to say that the heating wasn't from fuel burning or combustion heat, but more a lack of oil, or possibly water coolant not flowing properly.
What was the coolant water looking like? Rusty or a good antifreeze colour? Antifreeze can also be a bugger. A lot of the cheaper brands have a high hydrochloric acid concentration, which can eat away the block, so dilution levels have to be spot on. I am a firm believer in expensive coolant/antifreeze, or the genuine Nissan stuff. This was conveyed to me by Frans ( Tour de Frans ) many many many times!!!! Do any of the water ports look blocked? Could there have been a blocked water port preventing cooling around the no 1 cylinder?
I suppose checking for a blockage would be almost impossible other than trying to blast water into the ports.... but that would probably blast any obstruction out of the channels inside the block.... :confused: :confused:
PaulvdMerwe
Nickname: Paul
Post by PaulvdMerwe » 20 Jan 2016 08:51
Michael,
Jy het dit reg...
Ek het die injectors op die test bench gesit en sowaar. no 2, 3, 4 crack almal by so 170, maar no 1 loop sommer al hier van 50 af al uit. Definetief overfueling op no 1.
So dit los die een probleem op, nou moet julle my asb help met die volgende een voor ek kan begin reg maak aan die enjin.
Ek gaan dit in 'n aparte post sit, onder die Topic "Can you identify this?"
Gaan loer asb.
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Swakopmund Namibia
Current 4x4: None
Has thanked: 85 times
Been thanked: 96 times
Post by JoshJ » 20 Jan 2016 09:07
Cedric. Thats one of the main diffs between the ZD30 di and ZD30CRD. Mine has electronic injectors
Being alive is a Blessing!!
Joshua
Post by ricster » 20 Jan 2016 09:48
Brilliant.... well brilliant that the cause has been found.... not the damage it caused !!!
I honestly thought that the overfueling would have melted the piston differently, so we learn new things !!
Has thanked: 583 times
Been thanked: 313 times
Post by Tinus lotz » 20 Jan 2016 12:10
PaulvdMerwe wrote:Michael,
Jy het dit reg...
Gaan loer asb.
As google nie weet nie vra ma vir Micheal :salute: :rolling:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Has thanked: 72 times
Been thanked: 95 times
Post by Wilkie » 20 Jan 2016 13:33
Hi Guys,to all our diesel fanatics out there
The first sign of the injectors starting to play up ,is when you park your car at nite and the next morning you start it up and there is the rough coughing and white smoke and clattering of the engine....
the injectors cant hold its required pressures and it starts to leak RAW fuel onto the piston ,in doing so it also washes all lubrication of the cylinders . so when you want to start your engine in the morning,
the compression has now doubled because of raw diesel that leak through injector is now lying on top of piston and the friction of the piston is increased against the cleaned cylinder.
the crown of the piston takes the knock and starts to get hairline cracks which needless to say eventually lets go .
It pays to have those injectors calibrated and tested every 80 000- 100 000km
:mytwocents: :mytwocents:
DMH
Full Name: Tejan Pillay
Nickname: Tej
Home Town: durban
Current 4x4: 95 Patrol SGL 4.2D,
02 Hardbody 3L TD
Home Language: english
Has thanked: 15 times
Post by DMH » 20 Jan 2016 15:06
Thanks for that Wilkie. I've done just over 305000km on my 2002 Hardbody ZD30. She hasn't given me any major problems - had the turbo serviced once.
Perhaps the issues she's been such an old faithful is because she's been superslow going up hills for as long as I can remember. My 4.2D GQ does better on some hills than her - and that says a LOT. So instead of waiting for any grenades to go boom, I'll get those injectors calibrated and tested. Anything else I should do or look out for chaps? I'm about to do an oil analysis for the first time. Very curious to see what that picks up (but of course it's the next couple of analyses that will really shed some light).
Don't want to hijack this thread - so, happy to start a new one!
Post by ricster » 20 Jan 2016 15:20
Its easier and probably cheaper to just recon the injector tips on a TD42. The last time I did mine they were R425 each ( x6 ), and super easy to replace. Just be VERY careful with the diesel spill rail. The little pipes on there break very easily if the get twisted !!!
Not sure the costs on a ZD30 motor....
Return to “16. DIY Projects”
