Lubricants replacement for GQ
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
Good morning all
Time for oil change, diff oil change, gearbox oil change, transfer case oil change.
Currently I am on 290 125km , my last diff and gearbox change was on 195 000km I might have had gearbox changed about 50000km ago but I need to confirm
Engine Oil = I have been using Castrol Magnetec now for many changes so I will stick to that ( semi synthetic )
Diff Oil = recommended API GL 5 SAE 80W90
Transfer = recommended Dexron 11 ATF
Gearbox = recommended API GL 4 or GL5 SAE 80W or 90W gear oil
These recommended are per Haynes book , any other recommended and used with great success will be appreciated
Re: Lubricants replacement for GQ
Klink omtrent reg vir my ...maak net seker van die ratkas spec ...p c en gerrit het een probeer maar nie lekke gewerk nie
stobi_de
Full Name: Frank Stober
Nickname: stobi_de
Home Town: 51647 Gummersbach - Germany
Current 4x4: Nissan Patrol GR2 /Y61 (TBE45) from 1999, short Nissan Patrol GR1 (2.8 TD) from 1992, Volvo XC60 AWD
Home Language: German
Has thanked: 9 times
Been thanked: 28 times
Post by stobi_de »
Sorry, I do not speak Afrikaans.
maybe you take a look to the LIQUI MOlI oil guide (Castrol and other companies have a similar oil guide system)
http://www.liqui-moly.de/liquimoly/web. ... guide.html
The Nissan PATROL GQ is called here Patrol Y60
Frank
Has thanked: 1124 times
Been thanked: 1038 times
According to Nissan workshop manual, the following is recommended:
Transfer case, manual gearbox and steering gear: API GL4 (but I have been using ATF in my steering system). AFAIK, ATF in the transfer case was never recommended by Nissan for the Y60, only for the Y61, but on the other hand it's supposed to be the same transfer case... I think if you have manual hubs, you don't need ATF in the transfer case, but I would recommend checking what's in there now and using the same, as changing could cause problems.
I would also recommend mineral rather than synthetic for the gearbox, as the synchromesh doesn't seem to handle the synthetic oils well.
Diff: API GL5 unless it has limited slip diff.
There are charts for to determine the viscosity depending on the temperatures the vehicle will be used in. For the engine, 20W50 is good for -10 to 40 C
For transmittion, 75W90 or 80W90 is good for anything below 40C, at higher temperatures 140 is recomended but can only be used above 0 degrees C.
Hope that helps?
