Front Axle Lockers
Re: Front Axle Lockers
Hubs and diff lockers are above my common sense to fathom .. On Boezman the HARDBODY I had Auto locking hubs in front. I bought a set of manual locking hubs from Commercial and had that fitted ..
On the Patrol [Agarob] I had, it was this "you choose" set up .. The lock by themselves when 4x4 is engaged and the STAY locked going fwd or reversing as long as the transfer case is sending motion to the front wheels. I Never once found it necessary to use the wheel spanner on Agarob to lock the front hubs additionally.
Now I have iNyathi. 4.2 Diesel Patrol Y61. % speed manual .. and over and the above the standard Patrol 4x4 system as we all know, he has front diff lock as well [ARB nogal ...] .. It is a MASSIVE aid in tricky climbs and clambers sand and mud .. BUT steering exact becomes a bit of a problem. [It take more driver input to go where you should, not where the car wants to go, thus keeping the correct line is not as easy [SOMETIMES I deliberately take the WRONG line .. because I CAN :biggrin: :biggrin: ]
As for Auto diff lockers, I had my doubts -- Until Mike Swann i fitted as set of OZZI LOCKERS [auto lockers] on the Prado's rear axle .. And WHAT A PLEASURE they were .. I would anyday again install AUTO DIFF LOCK on the rear axle .. only neg is that it "clax clax clax" when you turn sharp on solid [i.e tar etc] surfaces.
Those auto ozzi lockers more than doubled the Prado's ability off road. If I was to buy a vehocle with LSD now, I would replace it with aut lockers straight away
I yet have to test and experience auto diff lock on the front axle ...
biggles
Full Name: Steven
Nickname: Steve
Home Town: Durbanville
Current 4x4: GUII Patrol 4.8
Has thanked: 21 times
Post by biggles »
Peter Connan wrote:
I may be starting to sound like a wet blanket, but I wonder about the the behaviour of auto hubs and auto locker together. I think the auto locker could accelerate wear and tear on auto-locking hubs substantially?
I agree, the impression I get is that the autolock is a fragile mechanism and I almost always have them locked when in 4x4. But my troll lives a black and white life. It is either off road or on road. My work bakkie lives a grey life. I will maybe have it in and out of 4x4 several times a day.
The high speed 4x4 on loose gravels roads is a definite drawback. And handling is effected in those conditions. People talk about having to adapt their driving style or becoming more sedate. I have engaged 4x4 under those conditions and I did not feel much difference in handling. So I don't think I would loose much by not engaging 4x4 when on gravel.
:layrubber:
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Post by mvcoller »
I have bought two Lokkas, one fitted on my 2011 2.5 Tdi Pathfinder and one NOT YET FITTED for my 2008 3.0 TDi Patrol.
I decided on the front lockers on these vehicles after experiencing my 1999 Terrano (now sold) that came standard with a LSD in the rear and I fitted a LSD in the front as well. It was all that was available at the time at a reasonable price for the Terrano, that must have have been around 2003 or 2004. Well, that transformed the Terrano! It was certainly a heck of a lot more capable!
If I could choose, I would go with a LSD in the rear and a locker up front. A lot of people will not agree with me, but the LSD makes a lot more sense on tar and hard surface roads. With a locker in the rear, you are forced to drive with an open diff on tar. I drive quite aggressively and when turning right in heavy traffic, with oncoming cars, a LSD bites and you can take off like a rocket. The Pathfinder scares me sometimes, when as soon as the tyres chirp, the power is cut midway into the turn and it does cause a certain amount of panic at times. An open diff will just lift the inside rear wheel, causing excessive wheelspin, the tyre will chirp, even smoke, but there would be slow or very little forward movement.
Most limited slip diffs are set up with about 75% slip and 25% bite, but you can induce it to bite a lot sooner if you know how to (I raced old Alfas Berlinas and Giulias, that came [some standard] with LSDs) in the inland regions, at Kyalami, Zwartkops, Midvaal, Welkom and even sometimes in East London and Killarney and had plenty of practice on how to cause the diff to lock up prematurely and corner with the help of a right foot. The guys with the Escorts raced with welded (locked) diffs, and on tar the LSD had a distinct handling advantage over a locked diff.
There is also of course the option to "tighten up" your LSD from 25% to around 75% bite, either by fitting more clutches or flattening the "ramps" in the diff internals to lock it up more easily. Do not underestimate a LSD!
The front Lokkas are quite cheap and work quite well, but the import duty makes it about 50% more expensive, with Custom Duties (about 20 %), handling fees (Post Office) and the VAT on top of all that! These fees came to R1900 on top of the roughly R4500 for the Lokka when I imported it for the Patrol a year ago. Delivery takes about two weeks.
I took the Pathfinder to Gearmax here in Jhb to fit the Lokka, and they charged about R2500 to R3000 about 4 years ago. On the Pathfinder, the front hubs are autolocking so I presume it will be slightly different handling characteristics between the Pathfinder and the Patrol, but I could be wrong. On the Pathfinder you do feel the steering gets a bit tighter and wants to straighten out all the time. But after a while you get used to it and hardly notice the "pull".
I have never been one to go into 4wheel drive on dirt roads, I prefer two wheel drive unless there are lots of loose pebbles (marbles), then I will go into 4WD. I prefer driving where I can induce understeer on dirt. On (the slower) trails you are constantly aware of the pull on the steering, always wanting to return to the straight ahead position. It is not annoyingly so, but you do feel it all the time. It is also not so hard that you can't hold it to go where you want it to go.
Where I do feel one heck of an improvement is on steeper inclines and on slippery mud. I would really recommend the front Lokka going by the improvement of grip on the Pathfinder.
I will soon take the Patrol to my mechanic to fit the Lokka to the front of the Patrol, but I am not planning an offroad excursion with the Patrol any time soon to go and test it out.
davidvdm
Full Name: David vd Merwe
Nickname: David - Hillbilly
Home Town: West Coast
Been thanked: 48 times
Post by davidvdm »
All this talk makes me think I have the wrong diff in the front of my Sani. Currently have a C200 that has nearly zero options for lockers. But do you get the H233 in a 4.88 ratio?
My H260 rear has the standard LSD that so far looks to be nice and tight (not in the car yet, but it's horrible to try and move around in the garage with both wheels locked together). I see for under $10Aus, I can get additional set of friction plates to tighten it up more.
But what to do on the front? Only option seems to be ARB at nearly R30k :surprised: Thats half the value of the Sani....
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
biggles
Full Name: Steven
Nickname: Steve
Post by biggles »
After the Baboons trip I can give a report back on how the Lockright performed:
I believe it is the perfect solution for the front of our vehicles. After I engaged 4x4 and locked the hubs the steering felt heavy. And I definitely felt the locker. After a few km I quite literally forgot it was there. The front is always locked so when crawling you get no wheelspin (unless both wheels are spinning). After a few km I did not feel resistance in the steering wheel. Almost like it needed to loosen up with some use.
As we need to engage the 4x4 before you get drive to the front axle and the autolock hubs do not engage until they get torque from the axle, in 4x2 the front axle does not move and having an autolocker in front will not have any effect on the vehicles driving characteristics. When you lock the hubs and engage 4x4 the front axle is locked. The Lockright only unlocks when it gets opposite torque from each axle (when you turn). when you lift a wheel you only get torque from one wheel so it doesn't unlock. I quite literally got used to the extra traction.
Quite frankly I am over the moon. For 7,700 cleared in SA.
A downside I have not explored yet is for people that engage 4x4 when driving fast on gravel roads. Then the locker will probably impact driving characteristics. I suppose I will try testing that sometime. It is not something I would do personally, I drive 4x2 at speed. I believe having not having a centre diff alone will adversely effect road handling but that is a debate by itself.
Contact Mike Swann, of Nisanzi he imported and advised me for the Powertrax Lockright. There is an australian one as well. That was slightly more expensive. As for strenght, some will argue you get stronger units, it handled the power of the "stormtrooper" up baboons for 8 hours of rock crawling. I doubt it will get a harder work out again.
:layrubber:
I stand corrected on this and maybe someone can correct me if I'm wrong, but as far as I know, and was told, the Patrols do have a center diff lock, to split the power 50/50 to the front and rear axle, obviously only when 4x4 is engaged. Again I speak under correction, but this is due to the Patrols not having a standard front diff lock, like the Cruisers.
biggles
Full Name: Steven
Nickname: Steve
Post by biggles »
ricster wrote:I stand corrected on this and maybe someone can correct me if I'm wrong, but as far as I know, and was told, the Patrols do have a center diff lock, to split the power 50/50 to the front and rear axle, obviously only when 4x4 is engaged. Again I speak under correction, but this is due to the Patrols not having a standard front diff lock, like the Cruisers.
Sort of correct. They do not have a differential in the centre, so it is the same result as a locked diff. That is my point, with a differential in the middle you get what they call permanent 4x4 where you can drive it on the road. Land drovers, some Jeeps, etc. Our patrols, not having a differential in the middle should not be driven at speed or on high traction surfaces in 4x4. So there is no difflock as such... because there is no diff iether.
:layrubber:
:thumbup: :thumbup: ... makes better sense now
Picasso
Full Name: HS
Nickname: Picasso
Current 4x4: Nissan Patrol
T3 Syncro
Home Language: German
Has thanked: 10 times
Been thanked: 45 times
Post by Picasso »
To Steve
How would you rate the performance of your vehicle (with front and rear locker) compared to the other vehicles (incl. the Jeep Wrangler with 2 lockers) which did the Baboon Pass ? :think:
andredurand
Full Name: andre durand
Nickname: leeuloop
Current 4x4: PATHFINDER
Home Language: afr
Been thanked: 37 times
Post by andredurand »
Can you please PM me Mike Swann phone no or post it thank you
Andre Durand
Nissan Hardbody 3.3 sold
Nissan patrol 4.5 sold
Nissan parthfinder 2,5 sold
Nissan navara 4l v6 4x4
