Is your Patrol "chipped"
- Ink
- Full Name: Jaques Horn
- Nickname: Ink
- Home Town: Middelburg Mpumelanga
- Current 4x4: 2000 4.5 patrol gl
Re: Is your Patrol "chipped"
dankie, wys mens net patrol is ma beter, ek was op die hilux forum ook maar daar kraak mense mekaar meer af as om raad te gee.
Life is a journy, enjoy the ride
- David M
- Full Name: David Marais
- Nickname: David Marais
- Home Town: Midrand
- Has thanked: 20 times
- Been thanked: 97 times
Dankie Franstour de frans wrote:Mini Patrol
The exhaust for the 4.5 is simmilar to the 4.8. Althou a 76 mm wont make a huge diffirance.
50mm to 57mm choke in the front. Remember the first box to be the size of the rest of the system. 63mm to the back with 2 boxes. This made the best power vs sound.
I would like to add,. the choke, some people would pull up their shoulders. Yes its wrong if the engine was reving over 6000rpm.
The VG30, the same for the distribitor/ chip setting. The Ac does not make a diffirance on the timeing.
Those 3l v6's are very underrated. Its a strong engine. Only becarefull for to wild on the cams , it will steal power @ 2000 to 3000 rpm.
Rdgs
Will be doing some measuring this weekend.
Would these specs change at all with branches (Think they are Maus) which I have?
Yep.... I have played with a couple of VG 30's and got some brilliant power out of them but was never happy with the low down power.... forgot to mention that the lifters where upgraded with imports from Japan....... 25 % of the cost of the standard one's from the stealers but definetly helped and zero tick, tick, tick......
- jonathan
- Full Name: Jonathan Venter
- Nickname: jonathan
- Home Town: Jacobsbaai
- Current 4x4: 2005 4.8 GRX
- Has thanked: 9 times
- Been thanked: 43 times
Ek het so paar maande Frans se advies gevolg met die free flow van my 4.5. Uitstekend! Baie bly ek het dit gedoen.
Weereens dankie Frans!
Dastech by Waterkloof het nie 'n goeie job op my Patrol gedoen nie!
Die Patrol het toe nog steeds nie goed ge-idle nie en 'n bietjie krag verloor. Ek het toe maar self gekyk wat die probleem is en het gevind dat die een sparkplug - no. 2- los was!
Ek het al die sparkplugs vervang en toe is al die krag terug en die idle standard en tot nou toe gaan alles nog goed.
- Full Name: Frans Reichert
- Nickname: Frans Reichert
- Home Town: Kimberley
- Current 4x4: Ford Ranger 4l 4x4 auto
Nissan Kingcab 4x4
Nissan Patrol 4.8 - Home Language: Afrikaans
- Has thanked: 3 times
- Full Name: Fanus
- Has thanked: 247 times
- Been thanked: 219 times
Hoe lank moet hierdie 57mm "choke" gedeelte wees?tour de frans wrote:Mini Patrol
- Has thanked: 1136 times
- Been thanked: 1047 times
As ek reg verstaan is dit tot by die inlaat van die eerste silencer?
- David M
My inlet manifold was done by a previous owner in about 2002. Just polished and very little meat removed. I have been warned about removing too much metal.Frans Reichert wrote:En wie het al laat aan die head karring, gasflow ens.?
However if you go this route insist, check and pay for an original Nissan head gasket. Mine went between the 5th and 6th cylinder last year because of an aftermarket gasket that only lasted 13 years,
