4.8 MAF sensor
- JoshJ
- Full Name: Joshua Joubert
- Nickname: Joshua
- Current 4x4: 2004 GL TD42
- Has thanked: 81 times
- Been thanked: 96 times
Re: 4.8 MAF sensor
Nice. Thanx for sharing. Is there a difference in exhaust smell?
Being alive is a Blessing!!
Joshua
Joshua
- jonathan
- Full Name: Jonathan Venter
- Nickname: jonathan
- Home Town: Jacobsbaai
- Current 4x4: 2005 4.8 GRX
- Has thanked: 9 times
- Been thanked: 43 times
Re: 4.8 MAF sensor
Ek kry nogsteeds ‘n petrol reuk, maar ek is seker dis nie so erg soos van te vore nie. Indien my verbruik nie terugkeer na normaal nie sal maar exhaust gasse laat toets en kyk om hom by iemand op die rekenaar te kry
- JoshJ
- Nickname: Joshua
Re: 4.8 MAF sensor
Ok. Met die CO sensors reg behoort hy dalk niu gestel te kan word met n CO meter.
Joshua
Joshua
- jonathan
Re: 4.8 MAF sensor
So unfortunately I have not travelled far enough to do a proper consumption test. But my initial feeling is that the consumption has not returned to the "norm" of 5km/l. What I did notice, after doing some coolant system maintenance and running the motor in die garage for some time, is that I have an exhaust manifold crack/leak.
Frans told me that I had a crack about two years ago, but I could never really hear it, until now. Hats off to that man
. Anyway, could a leaking exhaust manifold cause an increase in fuel consumption? At that time Frans told me not worry about it until it bothered me. It's not really bothering me, I'm just not sure what the negatives might be
- jonathan
Re: 4.8 MAF sensor
Ek kan glad nie 'n obvious kraak sien nie, en hoor hom eintlik net as die motor koud is. Sal mooi moet kyk of ek iets sien, kan dalk gasket seker ook wees
- Has thanked: 1141 times
- Been thanked: 1049 times
Re: 4.8 MAF sensor
I doubt a crack as small as you describe could make a measurable difference.
- jonathan
Re: 4.8 MAF sensor
Dankie Peter, dis presies wat ek wou hoorPeter Connan wrote: ↑06 Feb 2018 17:04 I doubt a crack as small as you describe could make a measurable difference.
- jonathan
Re: 4.8 MAF sensor
Quick update: Unfortunately it would seem there is not a workshop on the West Coast with an exhaust gas analyser. (One kind lady referred me to Supa Quick - because they mos werk met exhausts en daai tipe goed
) I took the troll to Nissan anyway to check of they pick up any error codes from the ecu. They did not see any errors but reset everything just in case.
After that on the first refill I got the best consumption ever! A wallet soothing 5.4km/l
We’ve a trip to Namibia coming up so that will be a good test if there was a real improvement.
Re: 4.8 MAF sensor
Dit is wat BESTE werk om MAF mee skoon te maak . OF Spanjaard se Carb cleaner [dis die carb cleaner wat die minste residue agter laat op n spieël]
