Battery Advice
Re: Battery Advice
Why don't you get a small intelligent battery charger an hook your battery to it so that a trickle charge will maintain your battery when the car is not in use?
Rhett
Nickname: Rhett
Home Town: Heidelberg
Has thanked: 163 times
Been thanked: 78 times
Re: Battery Advice
Post by Rhett »
Wilkie wrote:They will not tell you if you have a unit in or not
Security reasons
But think you have to go do load test on your battery first and if it passses .. then start looking for that tracker unit : :mytwocents:
I agree 100% first, try get two opinions from auto-elec. Might charge a R50 testing fee or something but well worth it.
Jorrie wrote:Why don't you get a small intelligent battery charger an hook your battery to it so that a trickle charge will maintain your battery when the car is not in use?
http://www.adendorff.co.za/Products/Wor ... y-Chargers
Also want to get one :yeahthat: Anyone tried these from Adendorff?
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
JoshJ
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Re: Battery Advice
Post by JoshJ »
I was present when tracker installed my device. And the techi told me that they put it in the same place everytime. Every car has its place where they put it. So I dont know. Might be along shot, but pm me and I'll tel you where to check. :mytwocents:
Being alive is a Blessing!!
Joshua
Has thanked: 1140 times
Been thanked: 1050 times
Re: Battery Advice
If that's true, then it's no wonder the theives take them out in 5 minutes flat!
Re: Battery Advice
I know it's not the ultimate solution but I have been doing what Jorrie suggested for almost 10 years now as I am away from home for extended periods. The trickle charger mainly supports the tracker unit.
But I guess you'd like to get to the root cause. Another option is to get a new one fitted. During the installation ask the installer to remove your old one first. I'm sure he'll find it in a few seconds.
NISMOnator
Full Name: Jacques Strauss
Nickname: NISMOnator
Has thanked: 19 times
Re: Battery Advice
Post by NISMOnator »
Ok guys,
Planning on getting that battery tested this weekend. Any place you guys can suggest to do a proper test on batt in Centurion area?
Re: Battery Advice
There is a couple of places ....batteries for you close to the old whanes gim complex they did some for me last week :thumbup:
just make sure its fully charged .
also disconnect the negative and check for any current draw between the pole and battery ...
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Re: Battery Advice
Post by Chris Skinner »
My Tracker was installed in the back right door behind the panel. Maybe look there first.
NISMOnator
Re: Battery Advice
How do I access that door without breaking the panel? Any detailed description how to get behind there? :think:
NISMOnator
Re: Battery Advice
Hi All,
Ok so I went to Batteries 4 all, Tinus this is the place I think you spoke about. Spoke to Jaco there and it was nice talking to someone that seems to know all about batteries and solutions and the do and donts. Well here it is in short. According to him I have two choices, get an charger or drive the vehicle more often. He said doesnt matter what battery I get. Letting the vehicle stand for 7 to 10 days will cause an issue. Especially due to the fact the week I do drive I dont drive that long distance either.
Ctek charger is definitely my answer like you guys suggested it seems. So then he tested the battery. Upon opening he immediately said the wrong battery were installed. Wrong size. The size according to him should be the 650. What do you guys have int he 4.8?
Test also showed battery is an borderline case. Could last a while or fall over anytime.
Just thought I will share this info. So I need to get a new batt now as first solution then Ctek charger expensive run....... :salute:
