DEATH WOBBLE ????
- Has thanked: 800 times
- Been thanked: 549 times
Re: DEATH WOBBLE ????
Grant
peter put a post with redoing the front axle there are bearing no ext on there iam on my phone and cant find it now
- Been thanked: 468 times
I remember something about that Tinus, but I think it was for the wheel axle bearings, not the swivel bearing. I need to either take a shim out on mine, or replace those top and bottom bearings.... just don't know the numbers
Welll.... I figured what the hell... let me take the shims out and see if there is a difference.
Oh yes !!! my steering is now firmer and I have NO wobble at 80-100 Km/h....nothing ....zero....nada.... boggerall..... iziko.....niks !!!!!!!!!!
I should have done this ages ago. I will however look at getting new bearings and replace the old ones and put the shims back. But as a temp fix it is perfect and took me around 30 mins per side with cleaning the old grease out and repacking new grease in!! The 2 bolts close to the steel plate that covers the steel brake disc did take a little effort to get out but anyone could do this job without any hassle..... was so quick I didn't even remember to take pics....
- Jules
- Full Name: Julius
- Nickname: Jules
- Current 4x4: Pathfinder
- Has thanked: 94 times
- Been thanked: 75 times
Cedric since it was so quick the first time you would now do it in double quick time when you repeat the process to take pictures for us mechanically dumb guys
ha ha.... I'm so excited to drive my Iron Maiden that has no more wobbly bits that I'd almost want to drive down to you and do it for you mate !!
Jules... I used this youtube video as reference and it really is exactly like this.
- Jules
- Full Name: Julius
- Nickname: Jules
Thanks Cedric
- Russ Kellermann
- Has thanked: 8 times
- Been thanked: 93 times
Ricster, Just a heads-up though,... depending on the amount of driving you do, expect the wobbles to return in a few months. Unfortunately thats just what happens.
Russ.
Russ.
Yip... This is definitely not a permanent fix, just a temp fix till I get my donkey into gear and buy the new kingpin bearings. Then I'll put the shims back to get the correct tension
Users browsing this forum: No registered users and 39 guests
