Many parts diagrams and lists of the South African Model 2014 CRD refer to the vertical exhaust pipe portion pipe just after the Turbo as the Three Way Catalytic Converter ???
I see no sensor before/after
1 - What is really inside that dump pipe ?
2 - Where is the DPF located ?
Part number : B08A0VS60A .....
Note that the front section of the Exhaust is listed as part " 200B0VV30A TUBE-EXHAUST,FRONT WITHOUT CAT CONVERTER"
There is nothing further on the exhaust that resembles a DPF ????
2014 30CRD - CAT/DPF Where ?
- Dungbeetle
- Full Name: Rudolf
- Nickname: Dungbeetle
- Home Town: Ellisras
- Has thanked: 60 times
- Been thanked: 67 times
2012 NP300 DC - platkar
- JoshJ
- Full Name: Joshua Joubert
- Nickname: Joshua
- Current 4x4: 2004 GL TD42
- Has thanked: 81 times
- Been thanked: 96 times
Re: 2014 30CRD - CAT/DPF Where ?
Hi, it sit in the down pipe. See the thread below. It can be removed. Doesn't cause any errors or issues. No sensors either.
viewtopic.php?f=43&t=5282&start=20
Being alive is a Blessing!!
Joshua
Joshua
- Has thanked: 800 times
- Been thanked: 549 times
Do i pipe and a chip makes it run a lot better like 400nm and 100kw on the wheels better phone me i will explain
- Dungbeetle
- Full Name: Rudolf
- Has thanked: 189 times
- Been thanked: 336 times
I think the 3.0 crd has only cats, no dpf's
- Dungbeetle
- Full Name: Rudolf
I eventually got confirmation of that. My next question is if the downpipe of the Di is the same as the CRD one?
Users browsing this forum: No registered users and 21 guests
